08-06-2019 08:08 AM
I purchased an 8 bay cRIO with 8 NI NI-9209 (32 channel voltage measurement). That gives me 256 voltage inputs (quite a lot !) I'm running the cRIO in scan mode in case that matters.
I now want to scan though all of those inputs in a for loop so each channel is read in turn so it can be used in my program. How can I iterate though each input and then each module without manually dropping each analogue input into my code?
08-06-2019 11:34 AM
This white paper will get you started on how to access the channels programmatically.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019VYLSA2&l=en-US
