DAC PCIe-6351
Hello, I'm new to LabVIEW and I'm running into some problems with a project I'm working on for uni.
I have to develop a LABVIEW VI for a DAC converter using a NI PCIe-6351 as a Data Acquisition Board.
I've already done the basic functions of write and read, but I must find a way to make everything automatic using a cycle.
The DAC should cycle through all the possible values of an 8-bit word and also read and load the input without the user having to manually press the switches.
After that, I must also measure the offset value, gain error value, DNL/INL, and maximum dynamic of the output according to the IEEE 1658 standard.
Now, I don't pretend that somebody else should do the project for me, but I'm drawing a blank here and any kind of help or suggestion would be greatly appreciated.
At the very least I would like to know how should I automize the reading procedure.
Attached to this message you can find the VI and some other information.
Thanks in advance.
Message 1 of 1
(1,031 Views)
