 meBaga
			meBaga
			02-06-2014 02:36 PM
I have used this robotics starter kit 2.0 previously, and done this setting before. It was working well. But I thought to do the "Robotics Hardware Setup" again. And now it is showing this error in the "deploy" process.
Can anyone tell me what is the exact problem?
02-18-2014 06:41 AM
Can anyone provide me any solution?
 chicken_81
			chicken_81
			04-16-2014 11:23 AM
You should do again step 3, remember turn of Robotics Stater Kit before doing
Network Troubleshooting Tips
Failure to detect the target may be due to one or more of the following:
1) The host computer and target are on different subnets.
2) The I have the LabvIEW Robotics Starter Kit checkbox is not checked correctly on the Starter Kit? page.
3) The MASTER switch on the Starter Kit robot is in the off position.
4) An Ethernet switch or router is off or unplugged.
5) An Ethernet cable is loose or defective.
6) The target was unpowered or booting during the scan.
7) The target IP settings are incorrect. To fix:
a) set the target mode switches to P Reset Mode(set switch 3 only to the on position)
b) Reset the target and wait several seconds.
c) set the target mode switches to Normal Mode(al switches in the off position).
To retry detection, select Rescan for Targets.
Good luck!
