DAQ 6009 OEM generic 200020 error
Good Morning
I have a problem with two usb 6009 oem daq.
Using Ni-DAQmx version 20.0.0 the system failed the self test with generic error -200020.
Apparently everything work, mainly the analogical imput in all channel ( both single than differential) but deeply isn't possible to use the digital trigger on pin 33. I try all configuration possible without success.
Testing in other pc with previous version has the same issue.
Do you know how is possible to fix it?
thank you
roberto
Message 1 of 1
(1,180 Views)
