I want to be sure that the board, mainly AI's and AO's, is as accurate as possible. To do that I will regularly calibrate it. With the E-series calibrate.vi I can perform a self calibration using parameters from EEprom (factory or user). But how do I update the user parameters in EEprom and copy them to the default area of the EEprom?
How should I proceed?
Same questions for the SCXI 1122 boards and the SCXI Calibrate.vi
Thanks for your help.
darby
