DAQ Assist Rate
Hello All,
I am looking to obtain a "useable" amount of data from my labview program. I am collecting data from the NI USB-6008 which has a sample rate of 10kS/s, Just using a simple VI using the DAQ Assistant I have it exporting the values into excel. The problem I am encountering is that with is I am having to much excel data to be able to actually use the information. I have tried to change the rate and samples to read in the DAQ to low numbers (1 sample to read at 2 Hz). But I am still getting a huge amount of data. In an Ideal world I would like to be getting about 1 data point every 2 seconds.
Thanks!
Message 1 of 8
(5,230 Views)
Hi MTGeo,
then just read one datapoint each 2 seconds!
Change your DAQAssistent from "HW sample rate" to "on demand"…
Message 2 of 8
(5,227 Views)
When putting the sample rate to "On Deman" how can I set the time of when collect samples. Idealy I would like one sample every 2 seconds for a period of 10 hours.
Message 3 of 8
(5,147 Views)
For something this trivial, a wait (ms) ore delay function can be used. The Elapsed Time function is also suitable.
Message 4 of 8
(5,137 Views)
Can these function be used in conjuntion with DAQ assist and Excel exporting?
Message 5 of 8
(5,085 Views)
Hi MT,
why shouldn't you be able to "Wait" for a certain amount of time in conjunction with DAQAssistent and Excel?
Message 6 of 8
(5,082 Views)
No clue, that's why I asked
Message 7 of 8
(5,070 Views)
It's the sort of question that takes less time to actually try than it does to type it out, post it, and wait for an answer.
Message 8 of 8
(5,056 Views)
