DAQ Assist not in express input options
I am trying to use LabView to perform some very simple Input / Output work and I was going to show this using the DAQ Assist, as I have many times before. However I just installed LabView onto a fresh computer. I am running 2015 (32-bit or 64-bit). I then installed NI MAX 15.0.0.
Does anyone know why I can't access DAQ Assist?
Thanks.
(3,318 Views)
Hi ryoden,
did you install DAQmx driver? DAQAssistent is part of the DAQmx package!
(Don't install DAQmxBase, it's a very limited package!)
(3,309 Views)
@ryouden wrote:
From the following link:
http://www.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du,n8:3478.41.181.5495,s...
Right... so install this one and you should be good to go
Cheers
(3,298 Views)
