DAQ Assist wont build
I am having issues with DAQ Assistant on Labview 2011.   I have the most up to date DAQmX drivers from the website.   Still have the issues after doing a full re-install of everything as well.
DAQ Assistant will find the channels and show the output in the top graph display area.   When you go to build the VI and click ok it just runs the "building" scanner bar and locks up completely.   It will also give the "Failed to create directory for auto recovery VIs" error message.
I had to install with ad-min rights, but cannot run under an ad-min account.   Do I need to set some kind of permission for the DAQ Assistant to work?  If so, which/and how do I set those specific rights.   Any other help?  Thanks in advance!
Message 1 of 15
(4,499 Views)
Anyone???  Project deadline is looming and I need to get a VI built as soon as possible.  Any help or input is appreciated.
Message 2 of 15
(4,469 Views)
This sounds like a file permission issue.  Since you installed Labview with administrative privileges, you may be able to change the permissions of the Labview directory (recursively) and see what happens.
Message 3 of 15
(4,465 Views)
Which permissions will I need to set - and where?   I only have limited acces as to what I can actually get to file permission wise.
Message 4 of 15
(4,463 Views)
???  Anyone ???
Message 5 of 15
(4,443 Views)
I forgot to ask which OS you are using.
Start by turning on Admistrator Account (I guess the true administrator account) and allow file/folder write access:
1. Go to Start, Programs, Accessories
2. Right-click on Command Prompt and click 'Run as Administrator'
3. Type in the following:
Net user administrator /active:yes
(there must be a space between administrator and /)
4. Reboot
Check if you have access.
Message 6 of 15
(4,429 Views)
The solution was found by doing a Google search on "Run application as administrator on Windows 7", one of the found sites provided these various options:  I would stay away from options 7 & 8 unless you know exactly what you are doing..
 from here
OPTION ONE
"Run as administrator" using a Keyboard Shortcut
NOTE: This will allow you to temporarily run a program as an administrator once until you close it.
    1. Press and hold Ctrl+Shift while opening the program.
    2. If prompted by UAC, then click on Yes to apply permission to allow the program to run with full permission as an Administrator.
    NOTE: If you are doing this is while logged in as standard user instead of an administrator, then you will need to provide the administrator's password before the program will run as administrator.
OPTION TWO
"Run as administrator" using Context Menu of Program
NOTE: This will show you how to temporarily run a program as an administrator once until you close it.
    1. Right click on the program's shortcut or an .EXE file, BAT file, CMD file, or MSI file, and click on Run as administrator. (see screenshot below)
    2. If prompted by UAC, then click on Yes to apply permission to allow the program to run with full permission as an administrator.
OPTION THREE
"Run as administrator" from Pinned Program on Taskbar
NOTE: This will show you how to temporarily run a program pinned to the taskbar as an administrator once until you close it.
    1. Right click on the icon of the pinned program on the taskbar to open it's Jump List. (see screenshot below)
    2. In the Jump List, right click on the program's name, and click on Run as administrator. (see screenshot below)
    3. If prompted by UAC, then click on Yes to apply permission to allow the program to run with full permission as an Administrator.
OPTION FOUR
"Run as administrator" from Start Menu Search Box
    1. Type in the file name (ex: cmd) of the program that you want to run elevated. (see screenshot below)
    2. Do either step 3 or 4 below.
    3. Press Ctrl+Shift+Enter to open the program (ex: cmd) elevated, and go to step 5 below.
    OR
    4. Do OPTION TWO as above to right click on the program (ex: cmd) in the search results at the top of the Start Menu, and click on Run as administrator. (see screenshot below step 1)
    5. If prompted by UAC, then click on Yes to apply permission to allow the program to run with full permission as an Administrator.
OPTION FIVE
"Run as administrator" using Compatibility Mode
NOTE: This will show you how to always have the program run as an administrator when you open it.
    1. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. (see screenshots below)
    NOTE: If you are doing this while logged on as a standard user instead of an administrator, then you will need to also click on the Change settings for all users button and type in the administrator's password.
        Run as Administrator-compatibility_mode1.jpgRun as Administrator-compatibility_mode2.jpg
    2. To Always Run this Program as an Administrator
        A) Check the Run this program as an administrator box, and click on OK. (see screenshots above)
    3. To Not Always Run this Program as an Administrator
        A) Uncheck the Run this program as an administrator box, and click on OK. (see screenshots below step 1)
    4. Open the program.
    5. If prompted by UAC, then click on Yes to apply permission to allow the program to run with full permission as an administrator.
OPTION SIX
"Run as administrator" using Advanced Properties
NOTE: This will show you how to always have only this specific shortcut of the program run as an administrator when you open it, and not from any other shortcut or .exe of the program.
    1. Right click on a shortcut that you want to run as administrator, and click on Properties.
    2. Click on the Shortcut tab for a program shortcut, then cllick on the Advanced button. (see screenshot below)
    3. To Always Run this Specific Shortcut as an Administrator
        A) Check the Run as administrator box, and click on OK. (see screenshot below)
    4. To Not Always Run this Specific Shortcut as an Administrator
        A) Uncheck the Run as administrator box, and click on OK. (see screenshot above)
    5. Click on OK. (see screenshot below step 2)
    6. Open the program.
    7. If prompted by UAC, then click on Yes to apply permission to allow the program to run with full permission as an Administrator.
OPTION SEVEN
"Run as administrator" using an Elevated Shortcut
    1. For how, see:
        How to Create a Elevated Program Shortcut without a UAC Prompt
        OR
        How to Create a Elevated Program Shortcut a Standard User is able to Run in Windows 7
OPTION EIGHT
"Run as administrator" Manually in Registry Editor
    1. For how, use the RUNASADMIN value with the full path to the program's file in OPTION THREE here: How to Run a Program in Compatibility Mode in Windows 7
Message 7 of 15
(4,427 Views)
Not much info from Msuff themselves if using Windows XP:
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/windows_security_runa...
The short version would be:
To start a program as an administrator
1.  In Windows Explorer, click the program executable file that you want to open.
2.  Press SHIFT and hold, right-click the program icon, and then click Run as.
Use of Run as is not limited to Administrator accounts.
Message 8 of 15
(4,425 Views)
See, my issue is that Labview was installed as an admin, but I cannot get ad-min rights without chopping my arm off and selling it.  I am using Windows 7.   Are there any ways to set the permissions without being an ad-min?  Or should I get the saw and turniquet out?
Its a federal computer and getting ad-min rights has been seriously backed up right now.   I know a couple people that have been waiting 4 weeks.
Message 9 of 15
(4,409 Views)
Can you ask the IT people to allow admin rights to execute LabVIEW?  Surely they have encountered that before.
Message 10 of 15
(4,407 Views)
