DAQ Assist
I'm running LabVIEW 8.5. I'm trying to follow the NI example titled "Using the DAQ Assistant to Automatically Generate LabVIEW Code." My problem is the DAQ Assistant does not show up on the Express/Input palette.
Message 1 of 12
(5,427 Views)
I have something called the Instrument I/O Assistant, does the DAQ Assistant now fall under that?
Message 2 of 12
(5,423 Views)
Hi Jim,
The Daq assistant should show up in both the signal express category in the functions palette and the Daqmx palette. If you type "daq assistant" into the search on the functions palette you should find them.
Message Edited by mickeyw on 08-05-2008 03:18 PM
Mike W
National Instruments UK&Ireland
Message 3 of 12
(5,414 Views)
Unfortunately it doesn't show up. We have the full NI Developers Suite of software, do  you know what disk that would be on?
Message 4 of 12
(5,408 Views)
Ok. Do any of the express VIs in the palette show up? If not it maybe that something wasn't installed directly, in which case re-installing may help. There should be a daqmx disk with the developers suite - the daq assistant should also show up in this sub-category of the functions palette.
Mike W
Message 5 of 12
(5,404 Views)
Lots of express vi's show up on the Express palette. My understanding was that I'd find the DAQ Assistant under Express/Input palette, but its not there. I do have an installation CD called NI-DAQmx Base which I installed, but it did not fix the issue.
Message 6 of 12
(5,398 Views)
DAQmx base is not the same thing as DAQmx which is what you need for the DAQ Assistant. What OS are you using? If a non-windows, then installing DAQmx base might make sense.
Message 7 of 12
(5,374 Views)
What version of NI-Daqmx are you using Jim?
Try downloading 8.6.1 from here and that should work.
Message Edited by mickeyw on 08-05-2008 04:33 PM
Mike W
Message 8 of 12
(5,369 Views)
What CD is DAQmx located on within the NI Developer Suite 2008? Other than DAQmx Base, there is no CD in the package that has the title DAQmx.
Message 9 of 12
(5,342 Views)
I don't have the developer's suite but someplace you should have a device drivers CD with DAQmx, NI-488, NI-VISA, etc. When you installed LabVIEW, it should have asked for the driver's disk.
Message 10 of 12
(5,340 Views)
