DAQ Assistant Graph
Hey folks.
So im new to LabView and have run into a little issue.
When i want to get a graph via the DAQ assistant i do get that but when i use N samples it shows the entire waveform and when i use Continuous Samples it like Zooms in and follows it very close. I want to see the entire waveform/signal like i do when i graph N samples.
Any idea on how to fix this problem?
Hope u are able to understand the problem! 🙂
(2,374 Views)
Hi Tartelette,
So you read a waveform from DAQAssistent and you can show it in a waveform graph, do you?
And now you want to append the waveform for each iteration of your loop? Maybe you should look in the waveform function palette -> analog wfm -> Append…
In the long run this probably creates new problems because you may create very large waveforms (or arrays of samples), which will slow down the graph and your whole VI…
(2,368 Views)
Well basically i want the graph to show Peak to Peak amplitude and 1 or more period. But instead it zooms really close to the signal and follows it.
(2,340 Views)
Hi Tartelette,
Well basically you should try to use the "append waveforms" function to build a larger plot from your smaller waveforms…
What have you tried so far?
(2,317 Views)
