DAQ Assistant/Labview crash
Hi:
I am running into a wierd problem when using DAQ Assistant to configure my channels from labview.
I am trying to configure a channel on NI-USB-9162 to measure accelerometer data. I create my vi and use DAQ Assistant (dbl click DAQ assistant vi on the block diagram) to change the default settings (all 4 channels set to aqcuire voltage). I remove all default channels and add a virtual channel (ch. 1) to acquire acceleration. When I press OK on the DAQ assistant to save my changes and return back to my vi, I get a message saying that labviewhas encountered an error and needs to shutdown. This is repeatable. If I cancel out of DAQ Assistant, there is no crash.
I am using labview 8.0 on a windows xp pro.
I apologize if this has been asked before.
-- Govind
(4,148 Views)
There's this issue [broken link removed; article no longer available] which is a known LabVIEW 8.0 / DAQ Assistant issue. Not precisely what is happening to you, but so closely related, I'd suspect a bug.
I would recommend re-writing it without using DAQ Assistant.
Richard
(4,125 Views)
Govind,
This is a known issue with LabVIEW 8.0, as described in this KnowledgeBase [broken link removed; article no longer available].  The solution is to upgrade to LabVIEW 8.2 or any newer version.
-Christina
(4,117 Views)
-Christina
Or re-write it to not use cheeze-ball DAQ Assistant?
Message Edited by Broken Arrow on 10-01-2009 10:22 AM
Richard
(4,112 Views)
Thanks, Broken Arrow and Christina. Appreciate the info.
-- Govind
(4,099 Views)
