DAQ Assistant analog output
Good Afternoon,
I'm trying to output a constant voltage (from 0 to 5 volts) through a DAQ assistant and running into problems.  Here's what I have now
And the error I'm receiving is
As always, Thank you all for your help,
Nicole
Message 1 of 10
(7,689 Views)
What type of device are you using?  Does it show up in MAX?
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 2 of 10
(7,686 Views)
I'm using a NI 9269, what is MAX?
Message 3 of 10
(7,683 Views)
I don't use DAQ Assistant but I bet that you can't use two of them with one DAQ.  You have to add a channel and configure one DAQ Assistant to output your two signals.
EDIT:  NI MAX is the Measurment and Automation Explorer that ships with almost every product and driver.  I'd like to point you to a NI website that explains it but there doesn't appear to be one! Smiley Sad
It's in the start menu under National Instruments.  OPen it and look in the help.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 4 of 10
(7,673 Views)
I am using two channels, unfortunately I can't get it to work even with just one channel being used
Message 5 of 10
(7,670 Views)
Close LabVIEW, open NI-MAX, double-click 'Devices and Inerfaces', click on your card, go to the test panels tab and verify you have any output.
Message 6 of 10
(7,667 Views)
Here's what I get on thes test tab
Message 7 of 10
(7,661 Views)
Have you tested your device in MAX?  What are the results?
Message 8 of 10
(7,654 Views)
When I select self test a pop-up appears and says that it passed the self test
Message 9 of 10
(7,651 Views)
Have you tried searching the forums for the error number?
http://forums.ni.com/t5/forums/searchpage/tab/message?filter=location&location=Board%3A170&q=error+5...
This is a common error and you quickly will see that you can't split your analog output between different DAQ assistants.
Message 10 of 10
(7,632 Views)
