DAQ Assistant for acceleration I need to set 4 different sensitivities
Good day
I was looking to build a vibration monitoring system using a NI-9234 and my original idea was to use the DAQ Assistant but I cannot seem to find a way to add a control for all four sensitivities to the from panel.
There is no connector for that input any suggestions  would be great I would prefer not to build the entire from Daqmx..
Thank you
Jay
(3,033 Views)
It sounds like you are ready to move beyond the quick simple setup capabilities that the DAQ assistant provides, but limits you to the simple things it can do.
You need to look at using regular DAQmx functions in your code.
Developer Zone Tutorial: Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisiti...
(3,025 Views)
May I also suggest: How-To Guide for Most Common Measurements
And there is a built-in Example in LabVIEW with the Sound and Vibration Toolkit called Vibration Analysis (DAQmx) that can get you started.
(2,981 Views)
