DAQ Assistant help..
How can you use the DAQ Assistant to correctly show the correct temperature readings of an infrared sensor? The sensor has 2 wires which are connected to an USB-6008 in the AO1 and GND ports... I tried all the options in DAQ Assistant>Acquire Signals>Analog Input>temperature and each option showed a reading that was way off. Can anyone help me?
(2,966 Views)
You need to provide more information.  What is the name/brand of this IR sensor you are using?
What is its expected output in output in volts for various temperatures?  Unless it behaves like an RTD, thermistor, or thermocouple, then you will have errors in using any of those Temperature choices.
See what kind of calibration curve the sensor has.  Read the sensor in volts and apply custom scaling based on the calibration curve to get a reading in degrees.
(2,958 Views)
