DAQ Assistant is missing in LABVIEW
I am using PXI 1031 system for my postgraduate project purpose ,this system has LabVIEW 8.5 version ,but I have a program in LabVIEW which is applicable in LabVIEW 2012, so I install LabVIEW 2012 in this system ,But the DAQ assistant is missing in LabVIEW 2012, but DAQ assistant is present in LabVIEW 8.5 , so then I  install 9.5.1 DAQ assistant in this system ,but after installing the previous DAQ assistant is missing in LabVIEW 8.5,and also no DAQ assistant is showing in LABVIEW 2012 .
Now how I can solved this problem ??
(2,791 Views)
Accepted by crossrulz
Hi tendoraj,
use only one of those LabVIEW versions. I would recommend to use LabVIEW 2012.
Background information to ease your decision: there is no DAQmx version supporting both LabVIEW versions!
(2,777 Views)
Thanks it's works now
(2,738 Views)
