DAQ Assistant isn't showing up
Hello, I have installed the student edition of LabVIEW 8.2.  I just now connected the ni-usb-6009 along with installing the accompanied cd.  I have also installed the most recent version of NI-DAQmx 9.2.2.  However, I am unable to find the daq assistant.  When I right click on the block diagram and go to measurement i/o, only Max config and VI logger appear.  What's wrong?
Thanks!
(3,346 Views)
It looks like you willl need to install 9.1.1 for the 8.2 version of labVIEW
Alan
(3,334 Views)
(3,331 Views)
And here is the complete compatibility chart, dang this was too hard to locate!
http://digital.ni.com/public.nsf/allkb/F4E76EC05118F72D8625773000672298
Alan
(3,320 Views)
Thanks so much!  Downloading now.  I'll let you know how it works.
(3,312 Views)
9.1.1 worked perfect.  After I downloaded it I also needed the 9.1.1 p1 (patch) for it to work properly... but it does work now.
Thanks!
(3,298 Views)
