DAQ Assistant not launching (LV 2013)
Hi all,
I have LabVIEW 2013 installed, and in all the tutorials it says that the DAQ assistant should launch once it is dropped onto the Block Diagram. I have been doing so (Express > Input > DAQ Assistant on the Functions palette) but nothing launches when I put it on the diagram.
Why is this happening? Are there any solutions?
(4,220 Views)
The default setting in LabVIEW is to configure when dropped, but this box can be unchecked. Double-click to configure if it doesn't automatically show the popup.
To change the setting go to Tools > Options > Block Diagram tab > "Configure Express VIs Immediately"
Cheers
(4,215 Views)
 Hi James,
I have tried double clicking it, and nothing is happening. Do you know why this is?
(4,206 Views)
Please provide the version of DAQmx that you installed.
(4,193 Views)
I installed DAQmx version 14.0
(4,187 Views)
You could try a repair or install the latest - http://www.ni.com/download/ni-daqmx-14.5.1/5271/en/
(4,182 Views)
Yup, sounds like a bad install 😕
Cheers
(4,176 Views)
