DAQ Assistant vs. DAQmx
Are we talking about the same VI? The one you posted has a sample rate of 1000/sec and you tell it to return however many samples are available.
In any case, I think I see a dataflow issue. Wire the error out of the dialog to the error in of the Start Task. That will make the Start Task occur after the dialog.
Message 21 of 21
(592 Views)
