DAQ Assistant
DAQ Assistant isn't working on my computer anymore!
If I double-click on the DAQ Assistant to create a new acquisition, it's working fine... I can see my hardware and select my input\output and configure everything...
But when I close the assistant, my DAQ assistant icon wasn't updated. No input or output pins was added to my icon.
On a existent VI, if I add or delete a channel, my VI become broken (see image)
Someone have a idea???
LabView 7.1
Ni-Daq 8.6
Board: NI cDAQ-9172
Thanks! Jean-Marc
(3,121 Views)
I've seen this question many times. Did you try a repair on your DAQmx installation? That usually fixes the problem.
(3,116 Views)
Good morning,
Did the DAQmx repair help?
Please use this link for help repairing NI drivers and softwares.
Lisa
(3,077 Views)
Thanks!
After a full reinstallation of LV, everything is working fine now...
(3,056 Views)
