DAQ Assistant
I am trying to use the DAQ Assistant to perform exercises in the text, Learning With LabVIEW by Robert H. Bishop. I am using LabVIEW Professional Development, Version 20.0.1. When I open Package Manager, it does show NI-DAQmx listed. However, there is no DAQmx-Data Acquisition palette in Functions>>Measurement I/O in the LabVIEW Block Diagram window. Can someone help me troubleshoot? Much appreciated.
(3,070 Views)
What version of DAQmx do you have installed?  You need at least DAQmx 20.0  (20.1 currently being the latest version).
(3,057 Views)
And did you install DAQmx  AFTER installing LabVIEW?
(3,034 Views)
Yes I did. I am aware there is an order of installation with LabVIEW.
(2,996 Views)
Package Manager says I have NI-DAQmx Runtime Version 20.1.0 and NI-DAQmx Version 20.1.0.
(2,994 Views)
