DAQ Board Trigger Control
hello
I am currently downloading and modifying raster scanning files from the community.
I want to add a trigger signal to it.
Currently I am using two daq boards.
One for data acquisition and one for scanner control.
When I apply the data acquisition trigger to the scanner using “trigger start vi” I get an error.
Is there any way to apply the trigger here ?
Or I want to create a fictitious trigger signal.
As a result, I want to synchronize the trigger start signal.
data acquisition vi
scanner vi
(1,320 Views)
error code -89125
(1,305 Views)
I've set the trigger line to be the same as the property node, but can I actually detect the trigger?
(1,264 Views)
