DAQ-Card 6533 to SCB-68
I need help with the code I need to be able to change the on/off time and pulse. I have my front panel but I am having trouble with the code. I am not sure how to make the vi talk to the device. Can you help with this???
(2,512 Views)
It looks like you are fairly new to programming the 6533. However, we should be able to get you started. If you go Help>>Find Examples (which launches the NI Example Finder), then in the Example Finder, we want to �browse according to task�. Then double click to expand out to Hardware Input and Output>>Traditional DAQ>>653x>>Buffered Pattern Output.vi. This example shows how to output data on the 6533.
If you are looking to change pulse on/off time, you would program a pattern that generates this �pulse�. For example, if you want a single pulse that is starts in two seconds and stays high for four seconds, you would program a specific pattern. The pattern could be clocked out at 1 Hz. So the pattern would be two zeros followed by four ones.
This is a lot of information to pick up on at once, so take a look over the example program, and let us know any questions that you may have.
Justin T.
(2,512 Views)
Ok, I have modified the code by looking over the examples but I am getting a buffer error. Can you look at it and let me know what I need to do to fix it?
Thanks!
(2,512 Views)
