DAQ Card Interface with GSM
I am planning to use NI DAQ cards for reading sensors inputs. But I cann't directly connect the DAQ card to PC. It has to wireless mode using GSM. Can any one help me how intract DAQ Card with GSM modem or any other methode ?
P.Surendar
(3,138 Views)
P.Surendar
You really can't do that. The easiest solution would be to use a CompatcRIO system using the GSM module from an Alliance member and implement a local control on that system and then install it in the remote location. But this is anything from straight forward and certainly not low cost.
Rolf Kalbermatter  My Blog
(3,117 Views)
