DAQ Input
Hi all,
I am using USB 6008 Daq configured with digital input in port 0. I would like to monitor and generate an event when the input comes (userevet/value signaling). How could i do it? Please give me any advice/reference.
Silver_Shaper | CLD
(3,167 Views)
You can directly take the digital input and keep the value signaling property inside the case structure and enable it only when the digital input is true.
(3,160 Views)
The value signaling gives me ridiculous result. So i went to producer/consumer design. Even thoughi had little problem. How can i solve this?
Silver_Shaper | CLD
(3,142 Views)
I need a clear picture what is the exact problem you are facing. Please explain the problem.
(3,137 Views)
