DAQ LED blink
I am having trouble integrating a few simple LV routines into one. I am using a NI-6221DAQ board in hope generating digital signals to control (pulse) two LEDs.
Currently I am able to turn an LED on and off using a boolean button and I have a sequence written for blinking LV's LEDs as attached. I would like to combine these two functions so that pulsing LabView LEDs correspond to actual LEDs. I am not sure how to insert the DAQ Assistant to combine these two actions.
Any help or advice would be greatly appreciated!
(4,605 Views)
Hi oleksie,
you should go through some basic LabVIEW courses. They are offered for free on the NI website...
You don't need local variables and you don't need a sequence to fulfill your task:
(4,580 Views)
