DAQ No Signal in Test Window and 200284 Error
Correction:
After "identifiying" the chassis and system, the model names have come up in their respective slots after restarting... But still no signal in the Test Panel window...
Message 11 of 13
(676 Views)
Hi ElecEng,
Even if you can't really change any of the wiring, it would be worth it to check that all of the connections are secure.
Since all of your actual hardware seems to be connected, visible, and operational now it doesn't seem like they would be causing such a strange inconsistency.
Message 12 of 13
(652 Views)
All the connections seem secure.
I checked all the signals on an oscilliscope and they all seem fine.
There was no noise and they were in the right limits.
Message 13 of 13
(639 Views)
