DAQ PID
Hi, I'm using LV 2019, USB-6341 and this VI:
By converting DDT to Scalar the output from PID looks like this:
My question is how to convert DDT to get output from PID without any data lost. Or maybe there is other way to use PID for DDT?
Thanks in advance for help 😉
(3,247 Views)
Hi Jakub,
all your terminals miss their label - why do you hide them? (And why don't you use more descriptive labels?)
You don't lose any data from PID output, but you lose them at the PID input due to the coercion dot…
The PID expects a scalar DBL input, so you could convert your DDT wire to DBL.
But then you would throw away 999 of the 1000 samples you are reading per iteration, but there are several options:
  • change the DAQAssistent to read 1 sample at 100Hz, then use FromDDT to convert to DBL…
  • don't change the DAQAssistent, but use FromDDT to convert to an array of DBL. Then take the mean of that array…
In general I suggest to use plain DAQmx functions instead of the DAQAssistent!
(3,160 Views)
Hi, thank you for your response.
Yes, I know about that, I just misspoke.
I tried your solutions and got the following error:
That's probably because I need to acquire at least 200kS/s, otherwise my reading is useless.
Is there any solution for that?
(3,148 Views)
Use a FPGA?
Running a loop at 200kHz on Windows whilst doing calculations is probably unrealistic, and updating an output at that speed seems unlikely. Certainly having reliable timing for a loop at 200kHz is impossible.
On FPGA, this becomes quite a bit more straightforward.
(3,134 Views)
