DAQ Series M Sample Rate and Number of samples
Hello Clint1000,
like crossrulz wrote the internal buffer can be the maximum size of your RAM, because you can set this size per default the values described in this KB are used
How Is the DAQmx Buffer Size Allocated for a Finite or Continuous Acquisition?
best regards
Alexander
Message 11 of 18
(1,615 Views)
Thanks..and thanks Duffy2007 for the link.  I always thought that the default values in Labview were the max the user could obtain.
Message 12 of 18
(1,589 Views)
One more thing..Is there a minimal amount of time you should acquire data for??  I had  400 hz waveform I was trying to read using 4k sample rate and 1000 samples.  The response, in another thread,  was that wasn't quiet enough  That would only give me 10 samples per waveform.  To me that's  enough but to someone knowledgeable it wasn't.  Is there a rule of thumb?? I know you want the max but what is the min I should try and obtain?
Message 13 of 18
(1,582 Views)
Hi Clint,
To me that's enough
When you get your results with the required accuracy then it is ok!
Well, as Nyquist and Shannon say: you need atleast twice your max signal frequency…
Message 14 of 18
(1,580 Views)
10x is my general rule of thumb.  But it really does depend on your requirements.  Especially with today's computers, more data is typically better.  You just have to watch your memory requirements.
Message 15 of 18
(1,574 Views)
So all these questions started because of sampling rates.  It looks like I need a simultaneous sample card. A PXI4340.  But I need 4 of them because I have 4 groups of 3 that I need measured simultaneously.   Next question:  What is the delay between each card??  is that a windows thing so its not accurate??
Message 16 of 18
(1,572 Views)
Accepted by Clint1000
Hello Clint1000,
multiple modules can be synchronized by selecting the PXI Express backplane 100 MHz clock as the reference clock source for all the modules, each Card then make a PLL to the backplane. The delay is then in a nS range
Page 25
http://www.ni.com/pdf/manuals/377014a.pdf
Synchronization Explained
best regards
Alexander
Message 17 of 18
(1,567 Views)
thxs..
Message 18 of 18
(1,553 Views)
