DAQ System Hanging Up/Monitoring Read Buffer
Hi All,
I am collecting data using two SCXI chasses with 1120 amplifier modules and SCXI 1112 thermocouple modules.
I am monitoring 12 input voltages and 4 thermocouple inputs.
I have set the samp,e rate to 2500S/s, and I am letting the software figure out how many samples to take each measurement.
Most of the time, the system runs fine, at about a 16ms loop time.  However, every few seconds, the system will hang up for ~500ms between readings.  Any thoughts as to what might cause these hangups?
I wonder if I am overflowing the read buffer.  Could that result in this type of behavior?  I think there is a way to monitor the read buffer, but I forget how to do it.  Can anyone tell me how to do that?
Many thanks.
Forbes Black
Lapsed CLAD, LV 5 - LV 2023 (Yeah, I'm that old...)
(3,415 Views)
Accepted by topic author diarmaede
You can monitor the read buffer by using the DAQmx Read Property Node and choosing Status->Available Samples per Channel.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,405 Views)
Hi Adnan,
Thanks for the help!  I am now monitoring available samples.
I have realized that the problem is not in that buffer.  I only get the problem when I have the "Logging" function turned on so the program is writing data to a text file.  I will look into that issue by monitoring the write buffer to see if that is what is overflowing.
Forbes Black
(3,385 Views)
I am not sure about your architecture but hope you are using a producer/consumer design pattern. You can find this by going to File -> New.. and browse down to Producer Consumer Design Pattern (Data)
Adnan Zafar
(3,366 Views)
Aha!  Someone else took a picture of the Producer/Consumer Design Pattern, but I did not realize it was a standard template.  This is EXTREMELY helpful.  THANKS!
Forbes Black
(3,364 Views)
