DAQ USB 6009 slow
Hi everyone
I'm measuring the charge and discharge of a capacitor using the DAQ USB6009.
But the graph and data stored start to get slow a
fter a few hours
Do you know why?
(3,138 Views)
Why?
Because you seem to create ever growing arrays?
Because you seem to open and close files in each iteration?
Do you really think you need to convert a waveform into a string array to get a minimum value?
(3,131 Views)
I need to collect the tensions per second, and saves them in real time, and then generate a table.
I realized that after 2000 seconds a instability in measurements, it begins and become slow.
Question: How do I set up DAQ so I get a smaller number of sample per second?
(3,105 Views)
In the DAQmx Timing function specify the sample rate.
(3,069 Views)
