DAQ and video acquisition
@Emanuele_S wrote:
Thank you very much, I am modifying the program, but I do not understand how you linked together the two error wires, I don't find the box you put just before the other box "error out", please let me know hat it is and what is used for.
Thank you very much alos four your patience.
Emanuele
It's called "Merge Errors" under the "Dialog & User Interface" pallete. If you want to know more than the name gives away, I would suggest checking out the help for the function.
Josh
Software is never really finished, it's just an acceptable level of broken
Message 11 of 13
(373 Views)
Well now it seems to work better.
Thank you very much indeed.
As you look very good at programming in Labview, may I jusk ask you some advice for a manual/book where I can find these basic pieces of information and also some examples for common VIs? I've got a couple of them, but they don't look very user-friendly. Please let me know
Thank you
Emanuele
Message 12 of 13
(368 Views)
Thank you
Emanuele
Not a problem. Remember to tip Kudo your waiters helpers Smiley Tongue.
I'm really not the best person to ask about learning material. I learned with a combination of experimentation, help files, and working with a CLA. I'm going to lob the question back up to the forum and hope someone else can respond.
Josh
Message 13 of 13
(361 Views)
