DAQ assis
I need to use the DAQ assistant to build a USB link (with the NI USB 6009). But I don't find where is this VI. I tried on "Function->Express->Input" but it is the only VI missing.
Does someone know how is it possible and how can I install it (I already tried to reinstall LabVIEW...didn't work).
I'm using LabVIEW 2015.
Thanks for your help!
(4,529 Views)
Accepted by Hooovahh
Have you installed all of the Device Driver software that should have come with your 2015 install? This would include DAQmx.
Here's a direct download link for DAQmx 15.1.
Cheers
(4,527 Views)
Yep, the classic "need to install DAQmx AFTER installing LabVIEW".
(4,506 Views)
Thanks you...it was that simple 😕
(4,491 Views)
