DAQ assistant. Sending signals to 2 different terminals
If you want to send digital signals  ( let's say like a Boolean switch) to cDaq-9174 (NI 9485 ). We are using 2 separate terminals. Do we need to create 2 Daq assistants in our codes 2 send separate signals to each terminals? can we create an array of Boolean and connect each to separate terminals
(2,443 Views)
Hi canucks,
just play with your daqAssistent and add a second channel!
Or get rid of that express I and use plain DAQmx functions as shown in all those example VIs...
(2,415 Views)
