DAQ assistant, acquiring data from my NI USB -6008 every "N" time
Hi guys.. can someone help me with the logic of the project I want to make.
I want my NI USB 6008 to acquire the voltage every "N" time, meaning I can change the time it will acquire the data.
Thanks and Regards everyone, I just need the logic, not the whole code/ block diagram
(2,750 Views)
It sounds like what you want is to make modifications to the rate at which data is acquired? If so, you can use the DAQmx Timing VI. However, I don't think this will allow you to make changes during acquisition, so you'll need to stop the task before changing the timing.
You could do this with an Event Structure tracking a Value Change event on the 'Rate' control that you create - when the value changes, inside the event structure, stop the task, change the timing, and restart the task.
There is a somewhat more complicated example showing the use of an Event Structure inside a While loop (the most common setup) called 'Handling Common User Interface Events' - you can find this using the NI Example Finder under the Help menu in LabVIEW.
GCentral
(2,724 Views)
Thanks cbutcher, will try this solution.
Thanks and Regards
(2,714 Views)
