DAQ assistant hangs up
Hey there,
I have two MyDaqs connected to the computer and am trying to run a LVDT from each MyDaq through the same DAQ assisntant. I acquired the first MyDaq fine but when I acquire the 2nd MyDAQ and press OK, the screen says 'verifying task'  as shown below and doesnt go past that point. Wondering if anyone could solve this puzzle
Gurung
(2,471 Views)
Hi Gurung,
Please, refer to the similar post: How can I control two myDAQ units simultaneously?
Are you able to see both of your myDAQs in Measurement and Automation Explorer (MAX)?
What happens if you swap the order and select the 2nd myDAQ (which hangs) first and then the first myDAQ as second?
Mikhail
RF Toolkits, Product Support Engineer
(2,453 Views)
