DAQ assistant- ignore 1st data point.
I am using LABVIEW 2009  and NI-PCI 6024E DAQ  to acquire data.
I made a simple vi, as attached below.
The DAQ assistant reads 10 samples, which are then passed on to a graph for plotting and saved in a file.
My question is, i want to ignore the first sample, i just want the sample number 2-10  to be passed on for plotting and saving.
How to do this?
Regards
poli
(2,359 Views)
Use Array Subset with an index of 1 at the place you want to remove the first data point.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,358 Views)
