DAQ assistant
Hi
I am not able to open the DAQ assistant in labview.  I am using Labview 7.1 and IN-DAQmx 8.9.5.
I have read the forums and tried uninstalling and installing the drivers, and when that didn't work, I uninstalled all the drivers as well as Labview and installed Labview first and then the drivers, but I still have no DAQ assistant.
I am connecting a USB-6009.
Any help would be much appreciated.
Message 1 of 9
(7,935 Views)
Accepted by topic author Herman Malan
Hi herman Malan,
   NI Daqmx-8.9.5 wont support NI Labview 7.1.
   http://digital.ni.com/public.nsf/allkb/97d574bb1d1eec918625708100596848
Thanks and regards,
srikrishnaNF
Srikrishna
Message 2 of 9
(7,927 Views)
Yeah, I guess I kinda didn't want to notice the fact that Labview 7.1 was not listed when I installed DAQmx.
Thanks for the help.
Herman
Message 3 of 9
(7,920 Views)
I noticed that DAQmx 8.9 supports Labview 7.1, but can't figure out if it supports the NI USB-6009.  Is there a driver that supports both Labview 7.1 and the NI USB-6009?
Herman
Message 4 of 9
(7,911 Views)
Hi Herman,
DAQmx 8.9 does in fact support the 6009.
The best place to find out if a specific version of DAQmx supports your hardware is in the readme.  Here is a link to the DAQmx 9.0 readme, you can typically find readme links on the driver download page.
Best Regards,
John Passiak
Message 5 of 9
(7,876 Views)
Thanks for the help, I found that about every version before 8.9.5 supports the USB-6009.  I ended up downloading version 8.1, which is working perfectly.
Message 6 of 9
(7,847 Views)
I'm unable to get DAQ Assistant with Labview 8.2 and device pci-6220.  What's going on???
Message 7 of 9
(7,155 Views)
Have you downloaded the DAQmx drivers?
Alan
Message 8 of 9
(7,140 Views)
Oh I see now, you have posted this question in multiple places with "other" informaation. In one post you say you have downloaded 9.2.2 DAQ and are using LV 8.2
Here is a compatability list, you down loaded the wrong drivers.
https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html
Alan
Message 9 of 9
(7,135 Views)
