DAQ assistent in block diagram URGENT!
It is possible that the example needs LV RT or FPGA, so this is not an issue here. Are you able to load and execute at least a single example (a basic one without any drivers and such)?
Otherwise, i get the feeling that your installation is messed up.
Did you install in the default directories? Did/do you have administrative rights on the system? What is the OS?
Norbert
Norbert
Expert: Geometry
Message 11 of 20
(1,313 Views)
MIght be so. I am not able to execute any of the DAQmx examples i found. i am using windows xp. And no, i didnt install with the default setting with Daqmx. I thought if i needed anything mihgt as well isntall everything. Would it whelp to re-install Labview with default then install the DAQmx default after that. I have full admin rights. It is on my own laptop.
Message 12 of 20
(1,302 Views)
What about other examples not using DAQmx? Do they load and run properly?
"I am not able to execute any of the DAQmx examples" Does that mean that you can load them, but running them will ......do what? Create error dialogs (something like invalid device, device not found or similar)?
If so, please simulate a device using MAX.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 13 of 20
(1,297 Views)
I can runs other examples. But not Daq. I can load it by it starts to scan my whole computer and most of the times only th front panel shows up. and i can not run the examples.
Message 14 of 20
(1,291 Views)
Then you have to simulate a device first and then choose this device for your DAQ application.
Norbert
Norbert
Expert: Geometry
Message 15 of 20
(1,270 Views)
And how do i do this? Do you have any tips or guide to where i can do this step by step? The problemis that i am doing a paper and working on a pump system. Where we are going to measure the velocity and drive of the motor and the prsure in the valves. And we have to use labview. And as i said i ampretty new to this. So i am trying to make this work. We are also suppsoed to control everything from labview. That is why we are using it. We have 2 presure sensors. and a moment sensor for the motor.
any help ?
Message 16 of 20
(1,255 Views)
Do you have access to the system with the DAQ devices? Maybe it is simpler if you can test some things there.
If not, you have to simulate a device as i already wrote in a previous reply (follow the link in that reply).
Maybe you should contact your local NI rep and ask for a short presentation of DAQ-applications.
What you describe is nothing uncommon for LV but without a basic knowledge of LV, you will have a hard time. So i suggest you to either try to visit a LV B1/2 class at NI.
Regarding your initial question:
I have never encountered a system where DAQmx was properly installed (palette and examples available) but the DAQ Assisitent was missing. It is possible that it was removed from the palette though, but this requires someone with appropriate knowledge......
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 17 of 20
(1,247 Views)
I'm having the exact same problem as has been described.  In MAX, I can see both the real device (NI USB-6211) and the simulated device which I have made.  I can also assign tasks and get a functioning output.
However, there is NO DAQ at all in the software.  If I go to express view->inputs there is no DAQ.  If I go to Advanced view, Measurement I/O, there is a blank empty white box...no DAQ at all.  If I go to search, and start typing in DAQ, or Assist, or both, there are no results - no DAQ at all.
I have a fresh copy of Labview 8.6 installed with appearetnly every feature I could ever imagine using...and the one I need is not there.
What do I have to do to get the DAQ setup?
Message Edited by nyair24 on 04-25-2009 01:21 PM
Message 18 of 20
(1,230 Views)
You have to installed NI DAQmx after the installation of LabVIEW in order to have access to the DAQmx API.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 19 of 20
(1,181 Views)
Hey again! I started from scratch and did what you said step by step and it all worked:) I got it up and running now:)Thanks ALOT for ur support and help.
From
SUnny
Message 20 of 20
(1,163 Views)
