DAQ channal synchronization
I'm using a NI 9401 DAQ board to trigger simultaneous pulses using it's 4 channels. In the DAQ assistant window, I set both the high time and low time to 2.5ms. The problem is when I monitor the pulses from the channels using an oscilloscope, I encounter phase shifts in the pulses of channels. I appreciate it if you can help me on that.
Mo
(3,218 Views)
Where is that dialog from? Do you have any code you could share? Do you have a screenshot from the scope?
Remember Cunningham's Law
(3,144 Views)
