DAQ channel name control empty
I'm having the problem that virtual channel names don't appear in DAQ channel name controls or constants. The proper channel type is selected, but nothing appears. I'm also missing a couple of contextual menu items on the control, such as add channel and edit channel. Any ideas?
I'm using MAX 3.0, DAQ 6.9.1f28, and Labview 6.0.3. A different system with MAX 2.1.3.14 works fine
(2,584 Views)
MAX 3.0 ships with the NI-DAQ 7.0 driver. You should not be using MAX 3.0 with the older 6.9.1 driver. I would recommend using the MAX version which ships with the NI-DAQ 6.9.1 driver. If your working system is identical with respect to NI-DAQ and LabVIEW versions, then I would recommend using MAX 2.1 with the non-working system as well.
Justin Britten
(2,584 Views)
