DAQ error when DSC module is installed
When I load any DAQ VI on diagram window an error occurr, "Initialization of the dynamic link library C:\winnt\system32\nidaq32.dll failed. System will terminate abnormaly", next error, "error loading lvdqaq.dll" , These errors happens only when the Data logging and supervisor control module from NI is installed on this computer (WIN NT 4.0 service pack 6) labview ver 7.- DSC ver. 7.0., When I uninstall DSC module , no error occurs with daq vi's. What I need is to create my aplication using DSC module and a traditional DAQ hardware. It seems that this issue happened before and was fixed using NIDAQMX , also there is a PALBASE.EXE file suggested in another discussion thread that it did not work for me. Any suggestion will be
appreciated.
(3,957 Views)
I'm not sure what is going on but here is what I would do. First make sure that you have adminstrative priviledges on that machine. Then uninstall NI-DAQ and the LabVIEW DSC Module. (You could also uninstall LabVIEW 7.0 and any other drivers.) Then install in this order: LabVIEW without any drivers, LabVIEW DSC, and then NI-DAQ and any other drivers.
JR A.
Application Engineer
(3,957 Views)
Thanks for your comment. DSC removed, Nidaq removed. Re-installed in suggested order. Same result. Same errors.
(3,957 Views)
I would recommend creating a phone support request at Request Support. An applications engineer will be able to assist you in making sure that all of the low level components are uninstalled and then you should be able to install without a problem.
JR A.
(3,957 Views)
