DAQ for Multiple devices : Complicated channel selection
Thanks for the help. I will let you know if I find out a way to do this.
Labview Learner
Message 11 of 13
(544 Views)
Can I ask why you want to use such a complicated scheme instead of one or two physical channel controls? Did you not read the answers the last time you asked this question?
Message 12 of 13
(537 Views)
@Ashaironix wrote:
What I am trying to do is Create a DAQ for multiple devices.
I have an array of physical channels and an array of boolean linked together via a synchronized scroller. Now when the user turns on the boolean it should store the respective channel. AND further when the user changes the device number, all the physical channels reset to say device 2 channels and I need to store all the physical channel values from device 1 and device 2. How can I achieve the above operation?
Thank you,
Oh just filter on device!
Yup the phy channel selection list can filter phy channels available to the selected device--- just a property node away!
Message 13 of 13
(523 Views)
