DAQ/labview sample at incorrect rates
I am trying to perform a very simple operation of DAQ assistent->filter->write to file.  The DAQ being used is an cDAQ-9172 and i am sampling at 10000 Hz.  For some reason when i use more than one channel, labview samples at less than 10000 Hz.  If i lower the sampling rate it still samples incorrectly, leading me to believe I am not maxing anything out in the system.I'm still unclear if this a DAQ or labview problem?
(2,754 Views)
can you please explain the settings in the DAQ Assistant? What settings have you choosed? N Samples, Continous? Have you got a wait function in your loop? Best will be, to post your example here and we can have a look!
Best regards
Alex R
Message Edited by Alex R on 02-10-2007 09:06 PM
(2,754 Views)
