DAQ mx Start Task error
Tengo un problema al adquirir una señal de voltaje con una placa NI-USB6009. Ya la usé en otras ocaciones  y funcionó bien.
Ahora trataba de hacer una prueba para leer las muestras sólo cuando el buffer de entrada esté lleno hasta un cierto limite, para que no se sobreescriba.
Pero por alguna razón, no puedo hacer que la tarea comience, salta un error -50405  y dice que:
"No transfer is in progress because the transfer was aborted by the client. The operation could not be completed as specified."
Alguien sabe qué es lo que esta sucediendo?
Desde ya, gracias
(3,369 Views)
Translation
I have a problem to acquire a voltage signal with a plaque NI-USB6009. I used it on other occasions and it worked well.
Now try to do a test to read the signs only when the input buffer is filled to a certain limit, to avoid being overwritten.
But for some reason, I can do the task starts, jumps -50,405 error and says that:
"No transfer is in progress Because the transfer was aborted by the client. The operation could not be completed as specified."
Someone knows what is happening?
(3,350 Views)
(3,348 Views)
