DAQ-mx continuous generation
I am using DAQ-mx for continuous waveform generation. How can i see what data has been generated in LabVIEW itself?
Somil Gautam
Think Weird
(3,881 Views)
If you attach your code we can show you. It should be as easy as adding a graph to your front panel and connecting it on the block diagram.
Tim
GHSP
(3,867 Views)
If you want to see exact data that has been generated, you may have to acquire the signal back using AI input and see..........
otherwise you can add a graph on your front panel and in the block diagram, connect data that is being given to Analog out....
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
(3,859 Views)
HI
Here is my code.
The thing is, it just takes the data once and generates it. What if i want to generate a new data everytime and write that data to a channel.
Somil Gautam
Think Weird
(3,840 Views)
Look at the example called Cont Gen Voltage Wfm-Int Clk-Non Regeneration.
(3,837 Views)
Please check, This code is giving some error. for the first time it runs. There is a problem with the Start task.
Somil Gautam
Think Weird
(3,821 Views)
OK guys, i got it. There was some foolishness i had done.
Didnt set the  write task to multiple samples!!!! Here it is just one sample.
Somil Gautam
Think Weird
(3,819 Views)
