DAQ problem on Version 8.5 doesn't work, it freezes up!!
Can anyone help me please?
I need to get daq assistant and a signal generator from the block diagram for a new VI, but found everytime I put it in place and try building the VI the whole labview development suit freeze up and I had to shutdown labview by task manager.
I can bring the daq assistant and the signal generator icons from the measurement I/O from the function palate. But, when the setup window launches it just freeze up and halts, can't do anything more. Did anyone else had the same problem?
I have labview 8.5 and my operating system is Win 7 pro with XP virtual mode instaled. I have already done some works on this version 8.5, but DAQ not seems to work on it, installed it not too long ago. can anyone help please? Thanks in advance.
(2,964 Views)
What version of DAQmx do you have installed?
(2,960 Views)
Ni-DAQmx version 8.5 it came with the Labview V8.5.   If you can help that will be great.  thanks
Vis
(2,951 Views)
I also have Ni-DAQmx version 8.3, but, I thought 8.5 would be the right thing to install.
Vis
(2,950 Views)
I just noticed you said you are using a virtual pc. I don't believe this is supported.
(2,945 Views)
  • But, I have Labview 8.5 functions without a problem?!
Vis
(2,943 Views)
LabVIEW 8.5 supports up to DAQmx version 9.3. I would definitely reccomend installing this version if you can.
There's a great little KB here I can reccomend:
http://digital.ni.com/public.nsf/allkb/DC7EBB1316F3406A86257894007BD75C?OpenDocument
Nick
(2,920 Views)
