DAQ problem
hi all
i want to read temperture and humidty in the front panel when i run the VI , i have the error in the picture below
When i read temperture only it works well and when i read humdity only its work well ,but 2 value dont work at the same time ..
Note :
i use DAQ and labview 8.0
Thanks alot
(2,883 Views)
You could have searched the forum for that error or message and found the answer yourself. You get that error when you have two or more tasks that use the same resource. Do you have multiple DAQ Assistants? If they are both the same (i.e. analog in), use only one and specify multiple channels in the single assistant.
(2,875 Views)
