DAQ - tasks?
Hi
I have designed a simple VI where I can write data out to a "current Out module" --- I´m a little confused about creating tasks and when and where to use them? I have attached a screen shot of my design. - In the "create channel" block there is a "task in" - if I create a task with let say DAQ assistant and connect it to this terminal, can I then disconnect the "min" and "max" terminals as these are specified in the "task"? - Furthermore the function of the "write block" isnt this specified in the task as well?? - I´m just a little confused about the whole idea with a task, as in my design I dont seem to need it???
ps. my design is "stolen" from an example
(2,766 Views)
If you create a task in MAX, then you do not need to also define the range, terminal configuration (i.e. RSE, Diff, etc),  units, scaling, etc. with the Create Physical Channel. A task also has timing information. You still need a DAQmx Write in order to define the actual ouptut voltage. Tasks are convenient and can save some coding.
I haven't used tasks in my DAQ programs yet. One reason is that I prefer to have complete control in the LabVIEW program which cannot be edited when deployed. I don't want an overly curious user going into MAX and messing anything up.
Message Edited by Dennis Knutson on 02-19-2007 07:49 AM
(2,761 Views)
Thanks......that makes sense.. I'll try it out
(2,741 Views)
