DAQ timing
I am trying to run what I preceived to be a very simple VI. I am using a DAQ assistant connected to a NI9401 which is housed in an NI9188. Wired into this is a motor encoder. What I was trying to do was record the number of encoder signal pulses in order to calculate the speed. (2048 pulses per revolution)
I am running the system for 5 seconds max during the pre-testing stages but I am finding that the data being obtained is timed over 40 seconds. Can anyone advise me as to where I am going wrong? or a simpler/more effiecient way of obtaining these results.
Regards
Joshua
(3,307 Views)
Accepted by topic author newbee1
that because you think you are passing "Time" to excel and you are. but the way LabVIEW thinks of time.  The value you send to excel will increment by 1 each second.  Excel thinks time increments by 1 each DAY! so your displayed time is off by a factor of 86400.
What you need is something like this:
That function you can't find on your palattes is available from the link.  You may need to adjust the BD Timestamp constant for you local zone (it doesn't travel well across timezones but efforts are being contemplated)
(3,281 Views)
I don't think this is a time formatting issue.
But I am confused since that data doesn't seem to match the VI.
1)The Write To Measurement File is set up to overwrite the file if it already exists.  But the Excel sheet seems to show several runs.
2) The Excel sheet seems to be showing the counter value each second.  But the DAQmx task is setup to output frequency.
(3,274 Views)
Thankyou for both of your responses. I have posted another question relating to DAQ timing if either of you both are able to provide some insight.
Best wishes
(3,242 Views)
